Need some help here...
Old 07-01-2008, 08:42 PM
08Ninja
08Ninja's Avatar
Default Need some help here...
In about a month I will be ordering a brand new Kenne Bell Blowzilla/Flowzilla to install on my 94 GT.I know this replaces the upperintake but, I basically want to do an engine rebuild and then bolt this bad boy on top, so my question is what all parts do I need for the rebuild? Whatever you can list would be great!!! I will be installing a BRAND new tranny as well to go with it, so I want to have the complete list of what I need to rebuild and slap this puppy on there. Thank you. I know I will need the following:
F5002 ('94-'95) 90mm Mass Air Meter/Inlet Assembly (90mm, 3.5" piping, 3-1/2"x12" long filter and 3-1/2"x3-1/4" throttle body adaptor.
Anything else you can help me with, and where to get it would be GREAT!! thank you.
08Ninja is offline
Old 07-01-2008, 09:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Need some help here...
have the block disassembled by a machine shop and inspected for wear then they will tell you what needs to be done.. you should never order internals until after that has been done cause you never know it may need a bore
mjr46 is offline
Old 07-01-2008, 10:12 PM
08Ninja
08Ninja's Avatar
Gotcha, basically the only thing I'm NOT going to replace is the block. If I need to, I will. I have a 2,500. budget to rebuild the motor AFTER I get the Kenne Bell S/C. If I knew I could replace what I needed with 1,000 I would just buy the 1,600 dollar 306 short block form texas hot rods. (says direct replacement for 302 and is built for S/C)
http://www.texashotrods.com/storefro...mp;i=233816138
So, is thata good idea? Then, basically EVERYTHING will be new, with the Kenne Bell...
Looking for any help here!
08Ninja is offline
Old 07-01-2008, 10:18 PM
mjr46
mjr46's Avatar
most likely you may be able to do yours a little cheaper if you can assemble the prepped block when it's done at the machine shop but either way you go will be good
mjr46 is offline
Old 07-01-2008, 10:28 PM
08Ninja
08Ninja's Avatar
Cheaper is better! I was just thinking I could save alot of labor by ordering a new one....
08Ninja is offline
Old 07-01-2008, 10:31 PM
08Ninja
08Ninja's Avatar
My plan is to order the charger, and everything else I need..and find a local tech and pay him like $25 an hour to help me install.
I live on base, and the auto hobby shop has everything I need to do it, including the lifts, cherry picker and etc.
08Ninja is offline
Old 07-01-2008, 10:34 PM
mjr46
mjr46's Avatar
too bad you live to far away.. you could pay me 25 bucks an hour to sit in a chair and point to what you need to do
mjr46 is offline
Old 07-01-2008, 10:44 PM
08Ninja
08Ninja's Avatar
haha, well you'd have to do a little work...lolI'm hoping to possibly find someone around here to do it. We'll see what happens. So, I'm buying a new block and the charger..what else do I need?
08Ninja is offline
Old 07-01-2008, 10:50 PM
mjr46
mjr46's Avatar
all the gaskets and fluids and depends on the boost level you desire a fuel system upgrade may be a wise investment too
mjr46 is offline
Old 07-01-2008, 10:57 PM
08Ninja
08Ninja's Avatar
I'll need new heads and etc right?? I have no real knowledge on this stuff...the block im getting comes with: \
Cast Nodular Iron Crank, Machined Beam S/R Rods,Ring Set - Moly - Pre Fit,Rear Main Seal, Block - Iron (Machined),Rod Bearings - 302 Ford, Main Bearings - 302 Ford,Probe Forged Piston - Ford 302 - FT, ARP Rod and Main Bolts, Balance Rotating Assembly and it comes performance Assembled with all new components
08Ninja is offline
Quick Reply: Need some help here...
