can someone help me out?
ok i have a 1992 mustang'vert im doing a 5speed swap in, im trying to pullout the old brake pedal so i can put the clutch pedal set in, so my question is can someone post a bolting diagram on how its mounted?
thanks in advance
Dan
thanks in advance
Dan
RE: can someone help me out?
you don't have to pull the column out!!........I dropped it down low and was able to get pedal assembley out fine..but then again I was doing a heater core at the same time so I had the entire dash out but in my 85 I did it with the dash still in and column still in too
You do NOT have to pull the steering column. 4 bolts on the bottom and it drops out. The brake pedal setup has only 5 bolts. 4 on the firewall and one in the middle just below the gauge cluster. Its really not that hard just a lil time consuming.
i have the 4 from the firewall out but one is still in there ive got the dash out now, im not doing anything with itthis weekendbut monday ill deff take a poke at it some more
oh and almost stock, the images you put up arent there,
thanks alot guys
thanks alot guys
