Shifting Problems
Old 10-23-2003, 10:24 PM
vfast
I ♥ Acer
vfast's Avatar
Default Shifting Problems
4k..man I shift'em at 5500
vfast is offline
Old 10-23-2003, 10:51 PM
95redGT
95redGT's Avatar
most stangs reach peak around 5100 don't they, at least the ones i've seen on dyno tests
95redGT is offline
Old 10-23-2003, 11:08 PM
vfast
I ♥ Acer
vfast's Avatar
about that.....who has a stock 'stang anymore?*L*
vfast is offline
Old 10-23-2003, 11:19 PM
95redGT
95redGT's Avatar
only the people who bought 'emless than a week ago it seems like</P>
95redGT is offline
Old 10-25-2003, 10:56 PM
sleeping9150
sleeping9150's Avatar
before u go spending all that money, have it checked by a mechanic (other than the dealership) that does free estimates. i'm betting it is either your pressure plate or clutch fork. i just went through that and i replaced the cable $21.99 from auto zone and then had the clutch fork and pressure plate replaced. total cost $521.99
sleeping9150 is offline
Old 10-27-2003, 10:18 AM
Strike
Strike's Avatar
I have to agree with 9150 here... go get the transmission checked -- by two mechanics unless you have one who you can really trust. If the cost to repair the transmission exceeds $1k, just put a new transmission in. It really does sound to me like your 2nd gear synchro is going bad, which is the most common gear to have that happen to since it really get the crap beatten out of it.
Strike is offline
Old 10-27-2003, 01:27 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
While I would agree to have it checked before you have it replace (which a tranny shop would do before they worked on it anyways), the a worn clutch cable / quadrant / fork / flywheel is not very likely, as it doesnt do the grind in all your gears. In addition, a cable / quadrant problem usually gets worse as you drive the car more, often times it wont grind at all for the first few shifts, then it gets worse. </P>
Where nostang at? Isnt this his are of expertise? <IMG src=smileys/smiley3.gif border="0"></P>
mdvaldosta is offline
Brandonfilipponi@yahoo.com
09-12-2015 11:39 AM
Mustangmalo
09-06-2015 05:22 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Shifting Problems
