chattering coming from tranny ??? please help
07-05-2008, 06:48 PM
I recently posted but no one replied
When am driving and I stop u could hear chattering and its really hard for the gears to go in ... what's happening tranny ? Clutch ? Clutch cable ?? HELP
07-05-2008, 08:05 PM
RE: chattering coming from tranny ??? please help
If there is chattering coming from the trans, could be a bearing goimg bad in the trans. Have you checked the fluid in it?
07-05-2008, 08:15 PM
Well chattering is not going to be the cable, do the noises stop when you push the clutch in?
07-05-2008, 08:25 PM
The chirping starts when my foot is on the clutch ... it had started chirping awhile back then it stoped and it started again
07-05-2008, 08:28 PM
If it just chatteres when your foot is on the clutch then it could be just your throw-out- bearing.
07-05-2008, 08:30 PM
If it doesn't have enough oil will the tranny make any noises ??
07-05-2008, 08:37 PM
If its the throw out bearing will it be hard to get in the gears ?? I have trouble getting the gears in
07-05-2008, 10:39 PM
I would check the fluid
07-05-2008, 11:33 PM
If it is low on fluid, its prolly to late. If you have never checked it, you should change it asap. 3 quatrs of trans fluid is not to expensive.
07-06-2008, 02:37 PM
Today I woke up early and I changed the fluid I put in the royal purple it got about 2 and a half quarts ... it feels smooth, can it still be the throw out bearing and my clutch ? Its hard to get it into 1st
