carb size?
carb size?
i decided to go ahead and buy my whole HCI setup sooner rather than later, the only part im unsure about is the carbim going to top it off with, im going with the edelbrock power package, i dont know if i should go with a 600 or 650 cfm carb
im worried that the 650 might be to much carb for my little 302.
RE: carb size?
is it a performer package or rpm package......performer package will work fine with a 600 tuned right as will the rpm set up but a 650 would work tofor the rpm but when I did a similar thing i HAD to lean out the jetting in the 650 dp I had
RE: carb size?
its the rpm kit, so i might step it up to a 650 if it will work good then, do you know what the stock size is?
i cant wait to get all this stuff done, the mustang club im in is having a weekend event at the local dragstrip in mid-augustand i want finish everything up and get it running perfect by then
RE: carb size?
if you are automatic I'd choose vaccum secondary but fora 5 spd car I'd go mechanical...my 85 was much more responsive with the mechanical secondary vs the edelbrock weighted secondary carb set up that was on there
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
