couple of questions
RE: couple of questions
Sounds like you might be buying someone elses problems as someone has stated. Definitely look at how much you're going to be spending just to get the thing driveable and stock-ish as far as the body is concerned. Definitely go over the whole thing to make sure your chassis isn't tweaked.
I picked an 89gt with a fresh rebuild on motor and a semi fresh rebuild on the transmission, 160k miles and about 400 dollars worth of asthetic stuff needing to be replaced for only 3k just to give you an idea. I'd probably buy it for 2k if the chassis is still in good condition and the car is running pretty nice.
i think the front end damage might be from running into a truck, as the front of the car looks pretty straight. like it might have went under the truck, and missed the majority of the damage.
the door, and rear bumper, are from a pushing the car the around the driveway type of incedent. the guy was pushing the car slipped and fell the car started to drift, and ran him over, and tweeked the door, and caught the corner of the house to damage the rear bumper.
i heard it run, it sounds healty, no pings or knocks, or squeels. its just not cosmectically pretty.
