Grade 8.8 metric bolt ok strenght for pressure plate?
Old 07-09-2008, 02:19 PM
jagman454
jagman454's Avatar
Default Grade 8.8 metric bolt ok strenght for pressure plate?
will these bolts work on my pressure plate? people at the hardware store tell me that these are equivalent to Grade 5 on SAE, is this true? will these work?
jagman454 is offline
Old 07-09-2008, 10:24 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Default RE: Grade 8.8 metric bolt ok strenght for pressure plate?
Will they work?
I'll let you be the judge of that.
http://www.dansmc.com/torque_chart.htm
ALMOST STOCK is offline
Old 07-10-2008, 10:19 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: jagman454
just go buy some hardened ones specifically for pressure plate use....I have used 8.8 before and been fine as the dowls hold it from twisting..but use the correct bolts anyway
mjr46 is offline
baddog671
07-26-2016 01:20 PM
88 orangepeel notch
10-05-2015 09:03 AM
Matt's 95 Stang
10-05-2015 07:16 AM
Explosive
10-02-2015 07:45 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Grade 8.8 metric bolt ok strenght for pressure plate?
