conversion ???
Old 07-10-2008, 10:07 PM
5project0
5project0's Avatar
Default conversion ???
Ok, i have this 1990 mustan 4cyl and i am going to convert it to a 5.0. I have the engine, and the 8.8 rear end. Im looking for a used t56 transmission. I waswondering how much this is going to cost me and what i will need. I know i will need a newradiator and gas tank and im sure a new clutch.
5project0 is offline
Old 07-10-2008, 11:08 PM
1988TTOP
1988TTOP's Avatar
Default RE: conversion ???
well that depeands man look for one in classifileds adss i know a rebuildt one is 800 from autozone and it a t 5
1988TTOP is offline
Old 07-10-2008, 11:15 PM
5project0
5project0's Avatar
autozone sells used transmissons?
I ment for the hole car how much it is going to be to convert it.
Old 07-10-2008, 11:19 PM
1988TTOP
1988TTOP's Avatar
they sell rebuildt transmissions that depends on how cheap u can get the parts and what u have now
1988TTOP is offline
Old 07-10-2008, 11:23 PM
5project0
5project0's Avatar
I have the engine, and the 8.8 rear end i just dont know what ill need next.
Old 07-10-2008, 11:26 PM
1988TTOP
1988TTOP's Avatar
u goin fuel injection or carb
1988TTOP is offline
Old 07-10-2008, 11:28 PM
5project0
5project0's Avatar
fuel
Old 07-10-2008, 11:32 PM
1988TTOP
1988TTOP's Avatar
u need a computer wireing harness maf driveshaft motor mounts
1988TTOP is offline
Old 07-10-2008, 11:36 PM
5project0
5project0's Avatar
thats all? i was thinking like new radiator suspension and lost of other ****.
Old 07-11-2008, 01:11 AM
FoxGT
FoxGT's Avatar
engine mounts
fuel lines (4 cylinder lines ran up through the drivers side)
computer
engine harness only
exhaust
throttle cable
sensors (you don't need a maf sensor if you have a sd eec)
may or may not need driveshaft, depends on the transmission you used
your tach will be double what it's supposed to read, You can fix this by swapping for v8 gauges or using a potentiometer on the input to recalibrate it.
If you aren't very good with electrical work then you may want to get the v8 body/dash harness aswell. I personally think it's pretty simple to mate a v8 engine harness to a 4 cylinder body/dash, but some people seem to have quite a bit of trouble with it.
I can't remember if that's all or not.... If i remember any more i'll type it.
Also, the t56 swap is going to cost quite a bit more. The t56 is a 6 speed. The T5 is a cheap swap (5 speed)
FoxGT is offline
Quick Reply: conversion ???
