slicks broke $hit... (LISTEN TO THE VID)
Old 07-12-2008, 10:36 PM
  #31
redpony88
redpony88's Avatar
Default RE: slicks broke $hit...
ORIGINAL: ckyguy68
The broom stick holds the hood up much higher than the stock rod But i didnt think i would be throwing a rod in this engine just by putting slicks on it.
ORIGINAL: bikeboy587
A) nice prop rod[/align][/align]B) i think that is a rod knock[/align]
but were you spraying? if so i'm not surprised it could have killed a rod. it's a stock motor with bolt ons, and it seems like you spray the pi$$ out of it. dont get me wrong a little spray is cool, but doing it too much to a motor that isn't BUILT will kill it [:@]
redpony88 is offline
Old 07-12-2008, 11:54 PM
  #32
cleanfitty
cleanfitty's Avatar
Sounds like she dun did...
cleanfitty is offline
Old 07-13-2008, 07:56 PM
  #33
jus4fun
jus4fun's Avatar
stock rod bolts and spray don't work well togather,look for a shortblock
jus4fun is offline
Old 07-13-2008, 08:02 PM
  #34
ckyguy68
ckyguy68's Avatar
I wasnt even spraying when it happened. Just a n/a 1-2 shift.It sounds like a rod bearing might have grenaded. I might even be able to get away with just dropping the oil pan and do the bearing like that. But i dont get why that would happen. I just changed the oil too, plus new radiator, 02s... the list goes on[:@]
ckyguy68 is offline
Old 07-13-2008, 08:43 PM
  #35
jtmustang
jtmustang's Avatar
its time to start tearing apart unfortunately.......[:'(]
jtmustang is offline
Old 08-16-2008, 05:10 AM
  #36
302army187
302army187's Avatar
did you figure out what happend?
302army187 is offline
Old 08-16-2008, 11:59 AM
  #37
Explosive
Moderator
Explosive's Avatar
That really sucks
Explosive is offline
Old 08-18-2008, 08:38 AM
  #38
holyshift
holyshift's Avatar
So did you figure anything out yet???? Curious to hear what you find
holyshift is offline
Old 08-18-2008, 05:20 PM
  #39
bballmac42
bballmac42's Avatar
I had something similar happen in a chevy truck. It was a 5-spd..totally different scenario, but same circumstances..sounded just like that when youd go to start it up again. snapped a connecting rod.
bballmac42 is offline
ctgreddy
10-14-2015 09:05 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: slicks broke $hit... (LISTEN TO THE VID)
