wideband o2 placement in exhaust?
Old 07-13-2008, 11:18 AM
andywear87
andywear87's Avatar
Default wideband o2 placement in exhaust?
is it alright to use 1 o2 sensor for tuning? where is the best place to put it? does it matter which side? please help i will be tuning with anderson pms and the wideband will be UEGO 2000. thanks
andywear87 is offline
Old 07-13-2008, 01:07 PM
silver91gt
silver91gt's Avatar
Default RE: wideband o2 placement in exhaust?
if you plan on putting a wideband in the stock o2 bung, take both o2 sensors off, run both stock narrowbands or none at all.
silver91gt is offline
Old 07-13-2008, 01:16 PM
Joel5.0
Joel5.0's Avatar
You can install the WB in the passenger side (bank 1) O2 bung, and feed the ECM with the NB simulation analog output from the WB controller for that cylinders bank. This is how I've set it for tuning with the TwEECer and have been able to keep fuel trim oscillation between ±4% (centered at 0%) on both banks.
Joel5.0 is offline
Old 07-13-2008, 01:52 PM
andywear87
andywear87's Avatar
well i am looking into leaving both o2 sensors in if that is better but i will put a 2nd bung just behind 1 of the other ones. would that be the best way to do it? and is the passenger side the side i should put it on or should i have 2 bungs installed and just plug the one im not using at that time so if i buy another sensor or i can swap sides and monitor that side also?
Old 07-13-2008, 02:24 PM
silver91gt
silver91gt's Avatar
ORIGINAL: Joel5.0
not all widebands have a narrowband simulation.
Old 07-13-2008, 02:39 PM
Joel5.0
Joel5.0's Avatar
The UEGO 2000 does.........
Joel5.0 is offline
Old 07-15-2008, 04:34 PM
FoxGT
FoxGT's Avatar
I would recommend the stock location aswell & using the analog output to the eec, then set it to the narrowband settings.
If the controller doesn't have an analog output I would get a different one that does. I don't know of too many that don't though.
I would only drill another hole & weld a bung in if you already bought it & it doesn't have the output to simulate narrowband.
FoxGT is offline
AIYNEM
06-12-2008 06:43 PM
Justin00Stang
S197 Shelby Section
04-02-2008 05:13 PM
Justin00Stang
VMP Tuning
01-29-2008 10:14 AM
svtmicah
06-22-2006 05:38 PM
sipynsyrup
06-11-2006 01:52 AM
Quick Reply: wideband o2 placement in exhaust?
