get rid of e.g.r.
Old 07-14-2008, 04:33 PM
jssblues
jssblues's Avatar
Default get rid of e.g.r.
on a 5.0 efi, is there any way you can delete the e.g.r. or does that mess with the computer??????
also wondering about the vaccum cannister, i have removed the smog a long time ago and am now rebuilding.......
all the vaccum lines for that and whatever is on the inner fender well, passenger side by the firewall, seem all useless and are just taking up space, any input would be greatly appreciated............
jssblues is offline
Old 07-14-2008, 04:34 PM
jakeachy
jakeachy's Avatar
Default RE: get rid of e.g.r.
If you are OBDI, you will throw codes.
Do you know that deleting the EGR will decrease your mileage?
jakeachy is offline
Old 07-14-2008, 05:40 PM
jssblues
jssblues's Avatar
all right never mind the e.g.r. , what about the other questions??????????
jssblues is offline
Old 07-14-2008, 05:44 PM
jakeachy
jakeachy's Avatar
just leave **** alone, messign with things that are not broke is futile.
removing emissions on a stockish engine is a waste of time.
like i said, you can expect a 1-3mpg drop if you remove egr.
jakeachy is offline
jtmustang
jtmustang's Avatar
i deleted all the smog crap ,egr and charcoal canister and i have no problems yet and no tune either
jtmustang is offline
Old 07-14-2008, 06:03 PM
jssblues
jssblues's Avatar
i dont have a stockish engine
306 with stockish but ported and polished heads
trick flow track heat
trick flow stage 1 cam
bbk long tubes
performance chip
etc
jssblues is offline
Old 07-14-2008, 06:07 PM
945LSTANG
945LSTANG's Avatar
ORIGINAL: jakeachy
i have a problem doing that. lol
anyone else have input on this topic? im curious and want to see if someone can back up these comments.
945LSTANG is offline
Old 07-14-2008, 06:35 PM
jakeachy
jakeachy's Avatar
anyone who knows anything about emissions knows that the egr contains gas vapors that havent been burnt through the combustion cycle... losing vapors, losing gas, losing mpg.
jakeachy is offline
Old 07-14-2008, 06:56 PM
15austin
15austin's Avatar
I removed my egr 7 years ago and I get 20mpg on the highway. I made a blockoff plate to fill the holes. Yea I have problems not toching stuff that aint broken to.
15austin is offline
Old 07-14-2008, 07:07 PM
Joel5.0
Joel5.0's Avatar
Remove smog equipment, remove EGR, install block plate, buy an EGR eliminator resistors plug, install it to the EVP connector and you're done. As soon as the EEC detects an EGR failure code, it will automatically delete/bypass its function + it will not affect A/F or driveability. The resistors plug will cause an EGR code 33 to be logged, and it will not cause the CEL to illuminate.
Joel5.0 is offline
Quick Reply: get rid of e.g.r.
