a/c vent switch...
Old 07-14-2008, 06:43 PM
chaotic50
chaotic50's Avatar
Default a/c vent switch...
why the f@#k does my a/c switch from the main vents to the defrost vents under any acceleration... doesnt shut off.. just switches to defrost... i cant figure it out.. even the smallest amount of gas in 4-5 gears it switches.... HELP PlEASE and has anyone else experienced this?????
thanks
Bobby
chaotic50 is offline
Old 07-14-2008, 07:35 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: a/c vent switch...
You have a leak in the vacuum system for the vents. Either the supply line is leaking, the vacuum canister in the fender well or the vacuum switch in the dash is the problem.
PRO50SC is offline
Old 07-14-2008, 08:43 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
either there is a vaccum leak as mentioned above or the one way check valve is bad out under the hood by the evaporator lines...it's sort of a funky looking black thing attached to hard plastic lines
mjr46 is offline
Old 07-14-2008, 09:00 PM
chaotic50
chaotic50's Avatar
thanks a bunch... i will check it out when its light out again!!!
mrtrodonet
09-19-2020 03:12 PM
vargas
06-17-2017 12:17 PM
PaulH2
20
01-31-2016 09:48 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
tmdm
09-04-2015 06:45 PM
Quick Reply: a/c vent switch...
