highway shimy
highway shimy
i have a 92 5.0 lx and at most speeds its fine but right around 75-80 theres a shimy, it seems like its coming from the back bu im not sure. could it be tires out of ballence or something bent?
highway shimy
My Corolla used to vibrate just below 70mph...after new tires, balancing & alignment it went away..smooth to 100+mph now..lol..though it takes a while to get there.
When's the last time you had the tires balanced? Just a thought..not sure if that would cause what you are describing, though.
highway shimy
I ONCE HAD A MUSTANG WITH A BAD SHIMMY BETWEEN 70 AND 80 MPH.....IT TURNED OUT THAT THE PREVIOUS OWNER HAD RUN NITROUS ON THE CAR WHICH BENT THE AXLES. ONCE I REPLACED THE AXLES THE SHIMMY MAGICALLY DISAPEARED FOR A WHILE. EVENTUALLY I HAD TO REPLACE THE ENTIRE CAR ONE PIECE AT A TIME AT A COST OF OVER $100,000 JUST TO MAKE SURE THE SHIMMY STAYED AWAY.
