help plz!
RE: help plz!
yes it was at the stock then, aight im pretty sure i did eveything right, yes i turned it the right way yes i used a light, i put it at 13 it was at 10. i put it back to 10 now, with all that said what could be the prob? is their a problem that usually happens or is this not a frequent problem
RE: help plz!
ya, i have double checked all wires plugs everything, still messed up, can bumping the timing cause any major damages?even tho i only ran it for a min then noticed it was messed up so i put the timing right back to normal and it was still messed up.
RE: help plz!
bumping timing shouldn't cause a major prob unless you are way off from what you think you are......but you say you have double checked and referenced all proper marks......could just be coincidence??
