help plz!
#21
RE: help plz!
Thats not the problem. first check you went the right way with the distibutor when you reset it to baseline. Probably a stupid question bud but where on the timing pointer are you using to set the timing because Ive seen people try to set it up at the circlular window and not at the top edge of the blade like your supposed too.
#22
RE: help plz!
ya i was wondering that becuase my car is running ****ty, im setting it at the edge. is this sopsed to happen tho, when i have the pout off and i set it where is should be, first of all do i put it back on when its on or should i turn it off then put it back on? Also, when i put it back on and look at the timing with the spout on, it wont be where it was with it off, it will show down in the circular part, is that soposed to happen when you put it back on?
#23
RE: help plz!
Heres how i've always done it. Set up you timing gun for power and number 1 plug wire signal, fire up the car, lossen off the dizzy holdown about 3/4 turn, pull the spout connector, set yout timing as desired then right away snug down the dizzy holddown. then plug the spout connector back in. You don't have to cycle the ignition unless you really feel like it. The spout is part off the system that allows the computer to automatically retard the the timing so as soon as you have the timing set and plug the spout bake in the timing will return to where the computer wants it.
#25
RE: help plz!
wait not sure ifthe rotor issuppose to point on the #1 plug when you kill it, but it is suppose to be on the #1 plug at "top dead center"might need to check that, could havegot missed up when you pulled the dizzy out some
#26
RE: help plz!
well i had the same problem when i messed with my 92. I know you have a 95 but, if i was you i would try and reset the ecu pull the terminals see if that works if not then restab the dizzy. Worked for me.
#27
RE: help plz!
hmm, well wut else can be causing this, maybe it just so happend that my injectors or fuel filter or somthing is getting cloged right when i started messing with the distributor? will a shop diagnostic show whats wrong? By unplugging the battery will that reset everything back to normal?
#28
RE: help plz!
a diagnostic show what's wrong??? your car needs to be troubleshot meaning first start with a KOER TEST!!! = SCANS THE CARS ECM FOR CODES or you can DIY KOER.....and if any are relavant to running condition from there a tech will go point to point on that system to narrow down the prob..there is no plug the car into a machine and instantly find the prob
#29
RE: help plz!
funny thing is, no one has really helped me, no one is saying possibillities. ok, i did everything right ive checked everything ive done all that, so with that said i dont need you guys to ask if ive checked the wires and this and that. no one knows wut it might be? what i could do? if i can reset the computer back to normal? should i just take it to a shop?
#30
RE: help plz!
Not trying to be a dick, im just getting frustrated and havnt really seem to got any help. im sure somone gonna talk about me being a dick and im not gonna get help o well then, if anyone knows then let me know plz
