throttle sticking at WOT - almost crashed tonight
Old 07-19-2008, 08:30 AM
aode08
aode08's Avatar
Default RE: throttle sticking at WOT - almost crashed tonight
I tell you, boy is that some scary shi when it happens. Especially if your in city traffic
aode08 is offline
Old 07-22-2008, 10:42 PM
jakemness
jakemness's Avatar
I just wanted to tell my story of stuck throttle, because it happened...today! I have had my 89 LX 5.0 Notch for a few weeks now, and have never had a problem... Today, it was raining, so on the way back from work i was sliding corners and whatnot, but then, once I got onto an extremely narrow two-lane, one way street, of course with heavy traffic (5 P.M.) I took off from a light at quarter throttle, if that, and as I lifted off the throttle... nothing happened, it kept accelerating... in that moment I reflected back to this post... I remember hearing about the problems people had with this, so, I tried to brake, which I knew wouldn't do much... Soon I was coming up to the next intersection with a red-light... I was probably doing 40... nothing crazy, but considering the speed limit was 25, and it is so narrow, I was worried... I tried to tap the throttle a fewtimes to try to knock it off whatever it was hanging up on, but to no prevail... I then put it in neutral and turned the key off as it began revving... This was right before the light, so i tried to hit the brakes, but of course... no power prakes... So I coasted through at a strong 35mph... People looking at me like I was an ***... I pulled over and popped the hood and tinkered with the throttle cable, and saw it pop back into place... So, overall, not as scary as spinning out or anything... but I was afraid for my little stang...
jakemness is offline
Old 07-22-2008, 10:48 PM
bighungrymatt
bighungrymatt's Avatar
glad you are ok, I would hate to be in that position...
bighungrymatt is offline
Old 07-22-2008, 11:34 PM
93 LX FiveO
93 LX FiveO's Avatar
i cut the carpet out today and it still feels like something is holding the pedal down
is there any way to adjust the pedal?
93 LX FiveO is offline
Old 07-23-2008, 12:22 AM
LT61
LT61's Avatar
Wow, glad to hear no one got hurt. This seems to be quite a common problem. Hopefully someone can figure this out soon. Best of luck to all with their diagnosis.
LT61 is offline
Old 07-23-2008, 04:40 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Might wanna look at that summit t/b. How long have you had it?
PRO50SC is offline
Old 07-23-2008, 08:00 AM
Alero99
Alero99's Avatar
im trying to finish up my HCI and i am having this problem also
think you have to get a good angle on the cabe to the botttom of the TB other wise the spring will lock up and throttle will get stuck open
Alero99 is offline
Old 07-23-2008, 09:35 AM
nseoi
nseoi's Avatar
CARPET!!!!!!! used to happen to my ever once in a while, redlined my old engine nasty, turns out it was being held at WOT by the plastic mats that the previous owner had on there
nseoi is offline
Old 07-23-2008, 10:32 AM
93 LX FiveO
i need to try it out in a parking lot
if it sticks ill try re-routing the cable.
right now the cable is routed high.. meaning it goes over the salt n pepper shakers and basicaly sits near the brake lines then it loops down and hooks onto the tb.
UrS4
10-03-2015 06:23 AM
BeatnikFink
10-01-2015 08:00 PM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
09-16-2015 03:07 PM
Quick Reply: throttle sticking at WOT - almost crashed tonight
