gears
gears
k ik everyone on here thinks im a dumbass for the whole 9" thing but i honestly dont care. this is what i want and what im getting. I would like to be ready to order monday and i just need to get some input on gears. Please discard ur views on the 9" and focus on gears. what gearing do you think i should run with a 5 speed? i was thinking 4.30s. please give me your suggestions and why. car is used to go to walmart and back. NO freeway driving. thanks in advance for your help, nathan
RE: gears
Go with some 4.56 gears[8D] Since you won't be hitting the freeway the 4.30's will be fine and will really enhance your lower end since you have an aftermarket cam. You will be shifting alot. If that is a problem, 4.10's would be another good option.
RE: gears
Super deep gears with a 5 speed make 1st seem like 4 Low in a 4x4.
If you are serious about driving to Walmart. You'll be doing alot of 2nd gear, or maybe even 3rd gear starts.
4 something gearing is popular with old style transmissions with a mid 2 first gear ratio. Most 5 spds are 3:1 making deep gearing pretty much useless unless you have BIG traction and no torque.
Do you use a sticky tire when you go shopping? Not a smart *** question. Just consider the torque multiplication will give a normal tire no chance.
RE: gears
ORIGINAL: Pearlkobra12
t-5's 3.35 first gear..if using a 26 inch tire and 3.35 t-5 4.10's IMO
RE: gears
ill be running it on M/T ET Drags that are 26/8.5. Do you think 4.30s will have me outgeared by the 1000ft? also i plan on strapping on a redneck performance c4 this winter when the stroker is built. would u suggest these gears over a 4.10 then?
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
