need to put my 94 on a diet, any one mind helping out??
RE: need to put my 94 on a diet, any one mind helping out??
those listed mods should help your launches, more weight transfer=better 60 ft
you dont need less weight so much as better transfer of said weight, but you gotta think, i think the tubular K member and A arms are like 43 lbs less than stock, and thats the only real thing your doing to reduce weight
like said, you could get a fiberglass stock style hood, Delete the A/C and Smog, etc
however, your gonna be hard pressed to hit that goal if you dont at least get some drag radials on there, at least get a spare set of tires and mount them on stocker wheels and keep em in the trunk when you go to the strip, at LEAST
ya i have a set of nitto drag radials on some stockies... the smog is already gone... gonna keep the ac...
the aluminum driveshaft is a lil weight too... i know its pushin it for those types of numbers, but im ready to push it. i am jus tryin to see if there is ne thing else besides what i have listed that i can do...
ne 1 else with ne other suggestions
ORIGINAL: FuzzyDiceRule
werent sn95 hoods fiberglass?
sn95 hoods are fiberglass but the aftermarket hoods are still a little lighter.[/align][/align]with those power numbers u want a 12.2 on motor?????!?!!! no offense On ****, ****, narrow baldtires i got a 13.4 on motor, with some better tires im looking at a 13.0-12.9 on motor and a 12.0 on my 125 shot...you can see my power numbers in my sig. [/align][/align]A good rule of thumb i heard is for every 100lbs u lose you gain 0.1 seconds[/align][/align]you should be hoping for a 12.9-13.2 on motor adn a 12.0-12.4 on spray[/align]
ya 12.2 on motor after all the mods for lightening it up and transfering weight better, and i think although pushing it its possible.. granted this was on the street but i ran a mach 1 that turned a 12.6 on motor, he did it twice and then had a couple of 12.7 and 12.8 runs with 60' times of 1.5-1.8.....
also man i ran a 13.9 with just bolt ons, stock heads, stock intake, stock cam, on bald 225/55 street tires
im goin to the track on saturday so i know street and track is diff, but im pretty confident ill be around his numbers...
what did your 60' times look like?
Cannibal_carnies
03-02-2023 06:17 PM
