trans. vibration at 80mph
Old 08-05-2008, 09:34 PM
jagman454
jagman454's Avatar
Default RE: trans. vibration at 80mph
I replaced the tailshaft bearing... i put a master kit in the 5spd, and i've ruled out the driveshaft because I took the driveshaft off and ran the trans threw the gears and I still got the vibration....this couldnt be a clutch issue could it? this is the first one i've ever installed...
jagman454 is offline
Old 08-10-2008, 10:31 PM
mustangsneverdie
mustangsneverdie's Avatar
it could very well be the harmonic balancer my car wouldvibrate bad at high speeds and turns out thats what it was
mustangsneverdie is offline
Old 08-11-2008, 12:42 AM
gr84u
gr84u's Avatar
I'd agree with the u-joints/driveshaft. Change the u-joints or get a new driveshaft!
gr84u is offline
Old 08-11-2008, 08:41 AM
calfroper_06
calfroper_06's Avatar
have you had the driveshaft balanced
calfroper_06 is offline
Old 08-17-2008, 01:44 PM
jagman454
jagman454's Avatar
its not the driveshaft, I took the driveshaft out and ran the trans threw the gears, it still vibrates and I doubt that its the harmonic balancer because I have not had a problem with that before, I just get the vibration now that the car is a 5spd not a AOD.... it must be the 5spd right? P.S. when i rebuilt the 90 T5 WC, but the cluster gear was messed up, so... I put a cluster gear from a 96 T5 in, and they both looked the same and everything same tooth count ect.... could this cause the vibration?
thanks alot!!!!
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
guitarman376
09-30-2015 05:54 PM
mdj89
09-23-2015 08:49 AM
Quick Reply: trans. vibration at 80mph
