Car wont start even with new battery
Old 07-23-2008, 06:43 PM
19MustangGT90
19MustangGT90's Avatar
Default Car wont start even with new battery
I had a old battery in to begin with, and that died on its own, so i went an got a new battery from autozone, 675 cca. When ifirst turnthe key it makes a "buzz" sound and it doesnt start, i turn the key again it makes a single "click" sound. I think the new battery is good, the head lights worked and didnt seem to dim. I didnt get a chance to try jumping it becuase of rain. Another possible problem is the positive lead, it has alot of battery acid on it. But would it still allow the headlights to work? as soon as i get the chance im going to try jumping it, then get a new positive lead. Thats all i can think of.
Any help is appriciated!
19MustangGT90 is offline
Old 07-23-2008, 06:47 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Car wont start even with new battery
Def sounds like a connection problem, check and clean them all. If the + lead is bad, start there. It doesn't take much to turn on an accessory but the starter draws a lot of juice.
PRO50SC is offline
Old 07-23-2008, 07:07 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check all grounds and make sure wires are tight on selonoid connection..and with the lights on try and crank it...if the lights go out completely when held in crank..then you know it's a bad connection somewhere
mjr46 is offline
Old 07-23-2008, 07:19 PM
19MustangGT90
the car wont crank, and when i turn the headligths on and try to start it, i see no fading of the lights
Old 07-23-2008, 07:22 PM
mjr46
mjr46's Avatar
you'll need a test light... with the key held in the crssnk position you should have 12v on the wire going down to starter..do you??
mjr46 is offline
Old 07-23-2008, 07:24 PM
mustangsneverdie
mustangsneverdie's Avatar
arc the solenoid with a screwdriver
mustangsneverdie is offline
Old 07-23-2008, 08:18 PM
19MustangGT90
i do not have a test light
Old 07-23-2008, 08:48 PM
mjr46
mjr46's Avatar
^^^go buy one then.. they are cheap and have many uses
mjr46 is offline
Old 07-23-2008, 10:11 PM
92projectcoupe
92projectcoupe's Avatar
Its probably your starter solenoid...I just replaced mine when I was having the exact same problem, relatively cheap, I say its the solenoid or starter itself...
92projectcoupe is offline
Old 07-24-2008, 12:10 AM
big ben
big ben's Avatar
if it ran before and you say the connection looks crapy then i can almost garentee its a bad terminal conection cleanit real goodthen take a steak knife and dig the hell out of the terminal and the battery post until you have good clean exposed lead on both ends then tighten her down real good. make sure you do it to both terminals and both posts. for added protection use dielectic grease or terminal grease.
big ben is offline
Quick Reply: Car wont start even with new battery
