IDLE JUMPING OIL PRESURE JUMPING
Old 07-23-2008, 09:06 PM
kurtban88302
kurtban88302's Avatar
Default IDLE JUMPING OIL PRESURE JUMPING
I HAD THIS PROBLEM FOR AWHILE MY CAR IDLE JUMPS UP AND DOWN AS SOON AS I START IT THE THE OIL PRESURE JUMPS MY MODS ARE TRICKFLOW INTAKE UPPER LOWER FUEL PRESURE REGULATOR SET AT 40PSI TIMING JUST SET PULLIESMAC HEADERS 24LBPND INJECTORS 65MM THROTLE BODY BASSINI CAT BACK KN AIR FILTER MY QUESTION IS CAN IS BE THE COMPUTER NOT KEEP UP WITH ALL THOSE MODS SINCE I DONT HAVE AN MASS AIR CONVERSION
kurtban88302 is offline
Old 07-23-2008, 09:10 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: IDLE JUMPING OIL PRESURE JUMPING
with idle erratic of course oil pressure will fluctuate as it is rpm dependant.....is the car still SD??? And what cam??? also enough with the caps!!![8D]
mjr46 is offline
Old 07-23-2008, 09:11 PM
kurtban88302
sorry yes its sd no cam
Old 07-23-2008, 09:17 PM
mjr46
mjr46's Avatar
first I'd run a koer test and check for codes and after that make sure Iac is clean and operational and there are no vaccum leaks
mjr46 is offline
Old 07-23-2008, 09:21 PM
kurtban88302
thanks where do they sell a computer flasher for this car
Old 07-23-2008, 09:58 PM
93 LX FiveO
93 LX FiveO's Avatar
walmart sells the ford obd-1 scanner
93 LX FiveO is offline
Old 07-23-2008, 10:14 PM
mjr46
mjr46's Avatar
google DIY koer test and you'll find instructions on how to do it yourself
mjr46 is offline
Old 07-23-2008, 10:34 PM
AdderMk2
Banned
AdderMk2's Avatar
lets see, for starters, you are running 24# injectors on a SD system... thats a big no no right there.
swap back to 19# injectors, or do a MAF conversion with a calibrated maf before you do ANYTHING else
AdderMk2 is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
Quick Reply: IDLE JUMPING OIL PRESURE JUMPING
