347 Stroker Build ?'s
Ok Guys so i have a friend with a 347 Stroker kit he bought and never used all he knew to tell me was that it was a 347 with probe flat top pistons and he has the blok work done also but it needs nothed where or how do you notch a block ive never done a stroker also i have an uncle who has a set for Ford Racing GT40 Castings they need built still never bin ran would these heads be suficient enough to suport it and what kind of cam should i use if i do i also have a 750Demon mechanical secodarys on it so will the heads do the job and what size and type of cam and intake do yall recomend. Thanks any help will be apresheated
RE: 347 Stroker Build ?'s
on a 347 you need at least a 185cc runner head..gt-40 heads = 302 parts.....and you need a good cam and all you need is a grinder to notch the piston skirt for rod bolt clearance
ORIGINAL: ctgreddy
the gt40's will work but won't let it breath like it should. and hopefully its only 30 over cause i hear anymore than that they loose strength.
