EGR Valve and check engine light
RE: EGR Valve and check engine light
ORIGINAL: ExMan01
how do you go thru emissions? did u just leave the egr in the same place and put a transistor in the plug? how does your car run without it?
i think im gonna leave all the emission stuff on. it doesn't rob that much horsepower and i like not having to worry about emissions. i just took my car to checker and did a KOER test and it gave me two codes:
12: RPM at idle out of range/high
34: 1) EGR valve not opening properly
2) Insufficient EGR flow or EVP voltage too high
Now what?
Now what?
34 - EGR Valve Position/Pressure Feedback EGR Voltage Above Closed Limit (O,R), PFE or EVP circuit has intermittently failed above the closed limit of 0.67 volts (M)
You have a problem with the EVP sensor reading too high for a closed EGR position state. Something as simple as the wrong EVP/EGR valve seal width will cause this problem, or the EVP installed is not the correct one, it will cause the code to be logged. BTW, if the EGR valve is seating OK (closed 100%) you shouldn't have any driveability problems.
yeah the car drives fine, although sometimes it will die under a load, if i'm engaging the clutch, hitting the brake and turning at the same time. how thick should the seal between the egr and evp be? should i just get a new seal from ford, or i'm i way off track here?
