idle and hesitating problem
Old 07-25-2008, 09:18 PM
rebelcowboy
rebelcowboy's Avatar
Default idle and hesitating problem
i just put a new motor in my car and i put a edelbrock performer rpm intake and a 70mm t/b,and my car seems to be hesitating when u give it gas and i cant get it to idle at 900,it goes up to like 1500 and u hit the gas and it will drop to 900 but if u press in the clutch it jumps back up.i need some help to fix this problem if anyone has any ideas they can give me.
rebelcowboy is offline
Old 07-25-2008, 09:37 PM
rebelcowboy
Default RE: idle and hesitating problem
ttt
Old 07-25-2008, 10:06 PM
rebelcowboy
ttt
Old 07-25-2008, 10:16 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what are your mods that require an rpm intake?.....also make sure you don't have any vaccum leaks
mjr46 is offline
Old 07-25-2008, 10:52 PM
rebelcowboy
the intake and t/b are all the mods i have right now i have that intake on it becuz i gave only 100 for it,the intake wouldnt cause it to hesitate would it?it has lots of power but when u hit the gas it takes a few seconds then it ***** to wall.could the tps or iac cause this?could the iac cause the idle problem im having.it didnt do it as bad before but it has always done it since i have had the car.
Old 07-25-2008, 10:58 PM
jakemness
jakemness's Avatar
Try putting fuel injector cleaner in...
jakemness is offline
Old 07-26-2008, 03:50 PM
rebelcowboy
ttt
Old 07-26-2008, 04:49 PM
rebelcowboy
anyone?
Old 07-26-2008, 07:13 PM
rebelcowboy
i think i foung my idle problem but i dont know wut is causin the hesitation,any ideas,i think the idle is my iac.
Old 07-26-2008, 09:06 PM
lxman1
lxman1's Avatar
What TB are you using? It sounds like your timing might be too slow causing the hesitation. I also suspect a vacuum leak causing the idle problems.
What year car is it?
lxman1 is offline
Quick Reply: idle and hesitating problem
