ACT relocation
Old 07-26-2008, 04:36 PM
Chr1s46536
Chr1s46536's Avatar
Default ACT relocation
OK so im installing an explorer intake, and it is the newer one without the boss for the ACT so i was planning on moving it to the air box, but im wondering if anyone here has ever drilled and tapped it into a CAI? I was going to do it on the bottom side so it wouldnt be visible or anyhting i just dont know if its a good idea or if the sensor will work there. Thanks
Chr1s46536 is offline
Old 07-26-2008, 04:40 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: ACT relocation
that will work fine... its the stock location on the SN-95's
AdderMk2 is offline
Old 07-26-2008, 05:14 PM
Chr1s46536
Chr1s46536's Avatar
is it located closer to the filter or the TB?
Old 07-26-2008, 08:05 PM
AdderMk2
Banned
AdderMk2's Avatar
about 3" after the MAF
AdderMk2 is offline
Old 07-26-2008, 08:41 PM
lxman1
lxman1's Avatar
I drilled and tapped my Exploder lower. I didn't install the rear EGR cooling hose barb though. I didn't feel like messing with that. I don't have the EGR valve hooked up anyway. I bought a EGR delete plate, but my cruise control throttle cable hits the metal heater hose piping so I can't use it.
http://i275.photobucket.com/albums/j...s/DSCN2525.jpg
lxman1 is offline
Old 07-26-2008, 09:18 PM
Chr1s46536
Chr1s46536's Avatar
ORIGINAL: lxman1
Well the lower is already on the car, and i already moved the wire from stock to where ill tap it into the cai this afternoon. Im not tapping it for the egr lines either im deleteing the egr and using the block off plate too.
Adder thanks for the info
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
svfetter
10-05-2015 11:39 AM
wraith777
09-28-2015 10:49 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: ACT relocation
