speedometer problems
RE: speedometer problems
so the speedometer doesn't register??? if so make sure the drive gear assembley is mated to the driven gear inside tranny on tailshaft and if it is it'll spin the cable at the other end where it is connected to speedo head unit ..if that turns then it most likely is a bad head unit
I mean you need a new one of these depending on the year:
this:
http://www.latemodelrestoration.com/...1&comp=LRS
or this one:
this:
or this one:
AS LONG AS THE CABLE IS TURNING AND NOT BINDING, and the gear drive assembly in tranny is fine, then that is the only other prob....find a known good used cluster and throw it is to test.. I keep a few spare ones just for that purpose
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
