TDC order?
Old 07-29-2008, 10:32 AM
shacar87
shacar87's Avatar
Default TDC order?
Does anyone know what the TDC order is...as in when #1 is TDC, what other cylinders are at TDC also? Replacing lifters, trying to make it easier. Thanks.
shacar87 is offline
Old 07-29-2008, 11:36 AM
15austin
15austin's Avatar
Default RE: TDC order?
#6 is also on TDC when #1 is. My engine is on the stand I went and checked. do you have adj rockers? On the pedastol mount it does not matter if it is TDC or not.
15austin is offline
Old 07-29-2008, 11:41 AM
15austin
15austin's Avatar
Here is a list of the other cylinders that are on TDC at the same time. The first # is TDC on the compression stroke the second # is TDCon the exhaust stroke. 1-6, 3-5, 7-4, 2-8.
I dont thinkyou could adjust the rockers on the TDC exhauststroke because there might be some cam overlap.
15austin is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Drastang
09-30-2015 03:48 AM
GLOCKer
09-28-2015 07:36 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: TDC order?
