gt40p heads and pushrods
I have these gt 40 p heads they have been upgraded about 10,000 miles ago w/ triple coil Comp Cams springs, 3/8 studs, guide plates, and machined to accept Teflon valve stem seals. and CRANE Roller Rockers the heads have a nice Home port job. well I lost the push rods how do I find a set for this? I just sold the heads on ebay and cant find the rods for it PLEASE HELP
RE: gt40p heads and pushrods
you don't!!! because push rods will be specific to each set up and theroretically when a combo is assembled push rod length should be measured via an adjustable checker.. and geometry set up accordingly.....it is possible that the set up may have used stock length 6.250 but I'd kind of doubt it
I've had 2 sets of p heads, one set required a shorter then stock pushrod, the other required a longer. The set that required a longer pushrod were actaully milled a good amount which I though was wierd.
