My battery wont charge
Old 05-10-2005, 07:32 AM
adam519
adam519's Avatar
Default My battery wont charge
Hey folks hope someone can help here... I have an 88 GT converted to mass air and out of the blue i developed a charging issue...
I have tried 4 alternators to no avail, with car at idle and thru RPM range the battery reads 11.85v and then with the car turned off it reads 12.10 or slightly higher or lower. There is a lil square device on solenoid, is that an external volt regulator?
Anyhelp is appreciated
Regards
Adam
adam519 is offline
Old 05-10-2005, 10:41 AM
hawkwitastang
hawkwitastang's Avatar
Default RE: My battery wont charge
Where's the little square device you're talking about? If your cars an '88 then it wont have an external voltage regulator unless someone added one for some reason or another. If your battery is reading 12.10v when the car is off you could clean the terminals and check your battery cables for corrosion wherever they're connected. 11.85v when the car is running isn't bad.
hawkwitastang is offline
Old 05-10-2005, 01:05 PM
adam519
adam519's Avatar
Ok the square box thingie is on the battery side of the solenoid as opposed to the starter side! As for the 11.85, that is with nothing running, my battery will die shortly after turning devices on as the charge is insuffecient.. that is atleat my theory....
one note, i have since cleaned all underhood grounds, cleaned terminals and posts also have aftermarket ground cable and I cut that and provided an oxidation free feed from the ground.... i am at wits end with this problem....
adam519 is offline
Old 05-10-2005, 01:22 PM
vfast
I ♥ Acer
vfast's Avatar
can you post a pic of the box
vfast is offline
Old 05-10-2005, 01:55 PM
adam519
adam519's Avatar
sorry its a bit blurry hard to stablizie a 75-300 lense!
[IMG]local://upfiles/16655/C644EA56E41B4D52B72177D41DB3BEAA.jpg[/IMG]
adam519 is offline
Old 05-10-2005, 02:02 PM
adam519
adam519's Avatar
here is a better image
[IMG]local://upfiles/16655/DA519B42170A4CA981ED3E39B2835C63.jpg[/IMG]
adam519 is offline
Old 05-10-2005, 02:12 PM
mustang8719
mustang8719's Avatar
Make sure the fusible link isn't burnt and the car is just running off the battery till it dies.
The fusable link is by the solenoid.
mustang8719 is offline
Old 05-10-2005, 02:19 PM
adam519
adam519's Avatar
dont know what that box is, but with or without still hardly any juice while car runs... interesting note.... THE AMP light is on while the car runs....
adam519 is offline
Old 05-10-2005, 02:22 PM
adam519
adam519's Avatar
damn wish I knew how to test the fusible link... have oftten wondered about that... and where beside solenoid is it? Is it attached to a wire attaching to the solenoid??
thanx so much guys
adam519 is offline
Old 05-10-2005, 02:26 PM
mustang8719
It attaches to the solenoid.If it burns it usually burns in half.Feel the wires coming off the solenoid and see if any feel empty.I will check in a few on my car to see which color it is.
As soon as I know I will post it for you.
Quick Reply: My battery wont charge
