top pawl gear wont come off
Old 08-02-2008, 09:08 PM
93 LX FiveO
93 LX FiveO's Avatar
Default top pawl gear wont come off
it wont budge. im prying it so hard it bent my screwdriver.. and its only plastic lol
is there something else holding it on? the cotter pin is removed and the lower quadrant is out...
did i miss something? thanks
93 LX FiveO is offline
Old 08-02-2008, 09:10 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: top pawl gear wont come off
I did mine a few months ago and I don't remember it being all that hard..pulled the pin and tapped it off
mjr46 is offline
Old 08-02-2008, 09:39 PM
93 LX FiveO
not budging.. thing is cracked and wont even come off
looks like the big spring behind it has a coil going thru the cylinder looking part of the pawl on the left side
i put my finger on it and it was definitely metal
Old 08-02-2008, 09:48 PM
mjr46
mjr46's Avatar
if it's already cracked break it off..with the metal quadrant you won't use the prawl anymore cause the firewall adjuster will do that job
mjr46 is offline
Old 08-02-2008, 09:52 PM
93 LX FiveO
i dont have a firewall adjuster
i got the summit kit with billet quadrant and adjustable cable
i didnt break it but got it off by prying the spring from inside the engine compartment and going back under the dash and dapping the pawl up it popped right off
can i buy a firewall adjuster and use it with my summit kit?
Old 08-02-2008, 10:01 PM
mjr46
mjr46's Avatar
I would assume cause that's what'll allow you to set your pedal height and adjustment as well as the adjustable portion down on the fork
mjr46 is offline
Old 08-02-2008, 10:57 PM
93 LX FiveO
well i got everything installed and working great
BUT.. summit racing did f* me over because the firewall adjuster IS part of my kit
right on my work-order is part # SUM-700102 which is the firewall adjuster
they will be getting a phone call first thing in the morning..
started at about 9pm and its 12 am now.. so 3 hours isnt bad for first time without taking seat out and on the floor in my garage
Old 08-03-2008, 02:12 AM
AdderMk2
Banned
AdderMk2's Avatar
would have taken less time for you to drive to my house
AdderMk2 is offline
Old 08-03-2008, 01:04 PM
redpony88
redpony88's Avatar
ORIGINAL: AdderMk2
haha. i didnt know you would install everyone's stuff for them.
any time i've put in a new quadrant i didnt have any trouble with them. pull the pins ans the spring and they come right off, takes a big 15-20 mins to pull out the old one and put in the new stuff, i havent bothered with a firewall adjuster, sure it's easier to adjust than getting under the car but it doesnt bother me. i may evantually go for one but i'm content with the quadrant and cable
redpony88 is offline
Old 08-03-2008, 01:08 PM
AdderMk2
Banned
AdderMk2's Avatar
now that my car is all together... I need something to keep me busy
AdderMk2 is offline
Quick Reply: top pawl gear wont come off
