# 1 cylinder location
I need to know where the nuber one cylinder is on a 92 GT. I could also use a quik refresher on how to set the timing. I just put gt40 heads, E303 cam, trick flow track heat intake, 70mm pro products throttle body. Someone told me I should advance the timing a bit. How much? And how do I do it? Any input would be greatly appreciated.
Here's a link to the firing order.</P>
http://www.allfordmustangs.com/techarticles/firingorder.htm</P>
</P>
