High revs and chugging
Old 08-03-2008, 04:02 PM
PortStangly
PortStangly's Avatar
Default High revs and chugging
My car is revving 1500-2000 rpms at idle. Up to 40mph I am getting chugging, but isn't present when at higher speeds. On deceleration when gearing down I am getting chugging as well. Any ideas?
PortStangly is offline
Old 08-04-2008, 01:34 PM
mftech
mftech's Avatar
Default RE: High revs and chugging
probably timing, Maybe crossed Ignition Wires. Possible too much Fuel being shot into motor are you carbed or fuel injected? plus what kind of intake setup?
mftech is offline
Old 08-04-2008, 05:19 PM
PortStangly
Fuel injected, stock intake
Old 08-04-2008, 05:22 PM
mattdel
mattdel's Avatar
take your MAF out of the intake tube and shine a real bright light into it. look for 2 tiny tiny little wires, side by side.
they should be as white as the background of this site. if not, clean 'em up with some MAF cleaner.
mattdel is offline
Old 08-04-2008, 08:33 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
run a koer test an make sure no codes are present...this should be one of the first steps taken in troubleshooting such a problem in your case..if no codes are present make sure there are no vaccum leaks
mjr46 is offline
CS2007
06-25-2019 09:45 PM
firehorse02
11-16-2015 11:28 AM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: High revs and chugging
