Windows Screeching?
Old 08-05-2008, 07:10 PM
swobrg
swobrg's Avatar
Default Windows Screeching?
Windows are screeching on the way up, easy fix or not? What would be the approximate price to fix?
swobrg is offline
Old 08-05-2008, 08:28 PM
redpony88
redpony88's Avatar
Default RE: Windows Screeching?
cost could just be your time. spray the weatherstripping down with lubricant and see if that helps, if not try running something through it like a screwdriver to make sure there isnt something in there catching it. if that doesnt work pull the door panel and see if you can hear it better inside the door, it could be the motor is dry and it straining when you put the windows up. if thats the case then pull it appart and put some grease in the motor as in the worm gear and what have you
redpony88 is offline
Old 08-05-2008, 08:57 PM
AquaFox
AquaFox's Avatar
my windows are doin that too in my 93 hatch, i gota check that out
AquaFox is offline
Old 08-05-2008, 09:08 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
ORIGINAL: redpony88
that's the last thing you wanna do cause then everytime you roll up the window you'll have this greasy streak of a mess.....I did that once and it took weeks to get it off/ outta the felt..........anyway..take the panel off and see what's rubbing/scrapping
mjr46 is offline
Old 08-05-2008, 09:15 PM
redpony88
redpony88's Avatar
ORIGINAL: mjr46
ORIGINAL: redpony88
thing is thats why you get dry lubricant, it works like a charm, it's even what we're told to use at the dealership. i'm not talking about wd40 or pb blaster, sorry about that
Old 08-05-2008, 09:18 PM
AquaFox
AquaFox's Avatar
whats brands of dry lubricant are there, does for sell one, do u think spraying the lubricant in the window tracks might help
AquaFox is offline
Old 08-05-2008, 09:53 PM
redpony88
redpony88's Avatar
we use 3m up at the ford dealership, and yea i'd recommend spraying it in the tracks first, but check to see if there's something in the tracks as well
Old 08-05-2008, 10:05 PM
HACKGT350
HACKGT350's Avatar
its most likely because the track is dry get some white lithium grease and spray that in the track and some of the dry lube he was talking about. i work for ford and thats what we use at our place too
HACKGT350 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
DreadPirateRoberts
09-26-2015 02:11 PM
wishinsky
09-21-2015 09:48 AM
Quick Reply: Windows Screeching?
