take off backseat
RE: take off backseat
at the front of the base, where the seat meets the carpet push back and the seat should be able to come up, there's a catch on each side, sometimes you gotta push pretty hard back. then there's a bolt on each side of the backs, i used a crescent wrench cause they arent tight and i'm lazy. then they can be slid off the center mount where it's just a rod welded to a mount the bolts in, if you want you can pull that too, on the back of those you have to pull up on the carpet to get it off the back plate the seat latches into then there's 2 bolts on each of those that will let the arms come out with the seat backs
ORIGINAL: mjr46
lift the bottom portion out and at the center and sides there are bolts holding back pieces down
