ring & pinion install
Old 08-08-2008, 01:04 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default ring & pinion install
installing 3.73 gears, does the pinion bearning have to be press fit or can i somehow get it on without a press? is anything anything else for installing gears i should know besides the crush sleeve and measuring pinion depth ect. (i got those covered. in pound tq and dial idicator)
FivePointOhh is offline
Old 08-08-2008, 03:49 PM
FLcracker9
FLcracker9's Avatar
Default RE: ring & pinion install
I'm assuming you have pinion and carrier shims, along withmarking compound to read the pattern?
FLcracker9 is offline
Old 08-08-2008, 03:52 PM
FivePointOhh
in limbo
si senor
Old 08-08-2008, 03:59 PM
Joel5.0
Joel5.0's Avatar
Press fit......
Joel5.0 is offline
Old 08-08-2008, 04:26 PM
racin66coupe
racin66coupe's Avatar
it does have to get pressed on there.. as far as i know
racin66coupe is offline
Old 08-08-2008, 04:57 PM
AdderMk2
Banned
AdderMk2's Avatar
put the pinion in the freezer, and the bearing in the oven @200 degrees
worked for me
AdderMk2 is offline
Old 08-08-2008, 05:07 PM
FLcracker9
FLcracker9's Avatar
It's supposed to be pressed on and off. I was able to get mine off with a clam-shell style bearing puller without any trouble (removed it 3 times before I got the correct pattern). I was able to reinstall it using a piece of steel pipe(with a few raps from a hammer) thatslipped over the pinion and engaged the bearing. It worked for me, but I wouldn't recommend it to anyone. It's always best to use the proper tool for the job. I was ina hurry because it was my Son's daily driver and only transportation. He destroyed the stock 3.55s (35" mud tires, a healthy 358 windsor, and an 18 year old!) and I needed it back on the road quickly. I set thebacklash a little tight, but after 2000 miles,backlash is perfect, it runsquiet, and the pattern lookedgood when we changed the lube last week.
Old 08-08-2008, 05:21 PM
945LSTANG
945LSTANG's Avatar
ORIGINAL: AdderMk2
worked for me
that sounds like a good idea. ill have to keep that one in mind.
945LSTANG is offline
Old 08-08-2008, 07:13 PM
Boss_Hotrod
Boss_Hotrod's Avatar
If you have new bearings keep the old ones to set up the pinion depth with. I have two pinion bearings I use to do it. I have just the inner race of one to press the new bearing/old bearing onto the new pinion and then a dummy bearing (middle enlaged witha dremel tool) to slip on and off the pinion to set the depth.
What adder said will work.
Boss_Hotrod is offline
Old 08-08-2008, 09:46 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I used a die grinder to eat out the inside of a new/test bearing so I can slide bearing on and off to read set up rear quick..and in set up process I don't use crush..just snug it down very lightly to a slight drag then set back lash and run pattern and add or subtract shim accordingly.....when pattern is correct then I set it all up with crush and then recheck all
mjr46 is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
Quick Reply: ring & pinion install
