after confirming connections..easiest way to test egr operation is run a koer test and hook/t in a vaccum gauge at egr valve connection and when egr portion of test is run.. you should see a rise on the vaccum gauge briefly.. if you do valve as porential to open then after that grab a vaccum pump and slowly apply vaccum to egr valve an it should start to idle rougher as valve is opened further..if it does all this... system is okay mechanically
