Track Heat/FPR fitment issues
Old 08-09-2008, 06:38 PM
redmustang83596
redmustang83596's Avatar
Default Track Heat/FPR fitment issues
I have a 5.0L engine in a car that isnt a Mustang. This requires me to run the intake backwards, meaning the throttle body comes off on what would be thedriver side. The problem I am having is thatmy FPR wont fit under the Track Heat intake. I cant put a spacer on the intake due to fitment issues with the hood. What can I do to fix this? I tried flipping the fuel rails, but they wont fit on the intake that way since they are pretty much molded to only fit one way. There a way to move the FPR, or get it so I can flip the fuel rails around, so the FPR is on the other side of the manifold? Thanks for the help.
redmustang83596 is offline
Old 08-09-2008, 10:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Track Heat/FPR fitment issues
have the hood modified so you can run a spacer
mjr46 is offline
Old 08-10-2008, 01:58 PM
redmustang83596
The options for modifying the hood on this car arent really, um, well there arent really options for modifying the hood. Any other ideas? I'm trying to avoid spending $600 on a rail/regulator system from aeromotive...
Old 08-10-2008, 02:12 PM
Venomantidote95
Venomantidote95's Avatar
well it pretty much boils down to buying a hood or getting a trickflow fuel rail kit from summit you can get that to work for you! you dont have to get eh areomotive anymore there are more options the trickflow rail kit is decently priced!
Trick Flow Specialties TFS-5158000R granted you will hvae to get teh appropriate fittings for the attachment to teh stock fuel lines still should come out cheaper than areomotive kit!
RUS-640880 should be the adapters for the rail to stock lines!
Hope this helps!
Venomantidote95 is offline
Old 08-10-2008, 02:25 PM
redmustang83596
Nah i got it, the crown vics have the regulator on the opposite side, they will work perfectly.. thanks tho
10-07-2015 07:02 PM
mungodrums
10-07-2015 04:01 AM
heslekrants
09-23-2015 04:02 PM
09-08-2015 11:50 AM
Quick Reply: Track Heat/FPR fitment issues
