94-95 5.0 same as 87-93?
Old 05-11-2005, 11:02 PM
Liquid_02
Liquid_02's Avatar
Default 94-95 5.0 same as 87-93?
Hi, I'm restoring an 87 GT, it needs the power train and body work. I can't find a parts car with the engine and trans anywhere near where I live, but I found a 95 GT with the 5.0. I was wondering if the engines, (and possibly the trannys) are the same as the 87-93. Thanks
Liquid_02 is offline
Old 05-11-2005, 11:11 PM
rcdblink716
rcdblink716's Avatar
Default RE: 94-95 5.0 same as 87-93?
Don't know bout transmission but engine is the same. The only difference is the intakes are different because they couldn't fit the fox body intake in the sn-95. Also, the 94 and 95 have hypeuretic pistons unlike the forged ones that would be in your 87. The 1987 doesn't have mass air so you would need to convert it for mass air. This is very easily and cheaply done with a kit sold by ford. Good luck, it will be easy.
rcdblink716 is offline
Old 05-11-2005, 11:36 PM
Liquid_02
Liquid_02's Avatar
Yah, I'm aware of the MAF problems, I had plans on converting it anyway. So is the intake manifold different, or is it only the plenum (upper intake some may call it)? Thanks! If the trans is the same I'll buy the car.
Anybody know if the trannys are the same?
Old 05-12-2005, 12:54 AM
94wyckdstang
94wyckdstang's Avatar
Yeah the upper intakes r different but those years had an aod and the sn-95 had an aode if im correct
94wyckdstang is offline
Old 05-12-2005, 01:30 AM
Liquid_02
Liquid_02's Avatar
I don't want an AOD, it's going to be a 5-speed car (T-5... if the 94/95's are T-5's that is)
Old 05-12-2005, 01:48 AM
Chris C
Chris C's Avatar
Ya they are t-5. Im not sure if you will need a older driveshaft but the tranny will fit.
Chris C is offline
Old 05-12-2005, 02:30 AM
P.S.I.cho
P.S.I.cho's Avatar
you youll probly need a driveshaft but that wont run you too much, good luck
P.S.I.cho is offline
Old 05-12-2005, 02:32 AM
primetime5.0
primetime5.0's Avatar
the input shafts are different lengths so it wont work unless you change it out
primetime5.0 is offline
Old 05-12-2005, 02:33 AM
91hatchgt
91hatchgt's Avatar
Tranny's are the same, and the driveshaft should be as well... It's just a different body, and the upper intake is different. Hope this helps.
91hatchgt is offline
Old 05-12-2005, 09:41 AM
Djs94stang
Djs94stang's Avatar
I agree with mustang30240...the input shafts are a different length. Also, the 95 GT has a world class T-5...not sure if the 86 to 93 is world class but I don't think it is....the internals are a bit different. The point is..not sure if you could just swap out the input shaft and make it work.
Djs94stang is offline
Quick Reply: 94-95 5.0 same as 87-93?
