Coolant in oil
Old 08-10-2008, 12:43 PM
jtmustang
jtmustang's Avatar
Default RE: Coolant in oil
what is your iac set at as far as with the key on engine off?
and the heads u can run a strait edge across and anything under .05 is fine over that and they will need to be decked?
did u put the head gaskets on the right way?
jtmustang is offline
Old 08-10-2008, 02:36 PM
Alero99
Alero99's Avatar
yep head gaskets had the word front etched in them so yea they were on right....
Alero99 is offline
Old 08-10-2008, 03:30 PM
93 LX FiveO
93 LX FiveO's Avatar
this is why you have em checked out before putting them on though
little extra peace of mind can save headgaskets
93 LX FiveO is offline
Old 08-10-2008, 05:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
personally I think all of you are wrong pointing at the head gaskets......think about it........low vaccum and coolant in the oil.....hmmmmm........now coloant can enter oil in more places than just head gasket ....like intake gasket misinstalled....if problem didn't occur until after install and low vaccum and idle issues would point towards a huge vaccum leak and couple that with coolant in the oil.....I'd be looking at intake gaskets and surfaces there and make sure you used the correct gasket for your application...just a guess based on your symptoms..who knows I may be wrong to...could be a crack in heads or intake
mjr46 is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
wraith777
09-28-2015 10:49 AM
belam
Oil and Oil Related Topics
09-23-2015 11:29 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Coolant in oil
