injector question
injector question
Will 24lb injectors hurt my performance in a stock motor? I am installing a Trick Flow street heat intake manifold and have set of 24lb injectors and a 75mm mass air I purchased for later. I figured while I was installing the intake I would put them in as well. I already have a 70mm throttlebody,underdrive pulleys,equal length shorties,off road h pipe,flowmaster cat back,bbk cai,e-fan,tremec 3550,and aluminum drive shaft. I just want to know if they will be ok with these mods. Thanks
RE: injector question
speaking from experience, it will make you slower on a stock motor, unless you have an adjustable fuel pressure regulator.
stock 19# injectors are good to around 300hp.
when I had a stock longblock, an edelbrock intake, and a B-303 cam I had to lower my fuel pressure to only 29psi to get an air/fuel of 13.5-1 with 24# injectors.
treesloth
09-28-2015 07:03 AM
