notched pistons
notched pistons
I have an 86 gt and as you all probably know it has the flat top pistons.... I am about to have the trick flow track heat 360 hppackage installed, and i need the pistons flycut first..does anyone know ballpark how much i should get charged to havethis done..???????
RE: notched pistons
DEPENDING ON LOCATON 150- 200$ MAYBE CHEAPER (unless there are furth problem once they get in there).. SAVE SOME MONEY AND GO AHEAD AND TAKE INTAKE OFF ..ETC. THAT WAY THEY CAN JUST POOP THE HEADS OFF AND GET TO BUSINESS MIGHT EVEN SAME U MONEY ON LABOR DUE TO THE TIME THEY WILL SAVE..
P.S.member ull need to tow vehicle to shop cause it want be operational only down fall if u dont have a truck or suv.
RE: notched pistons
ORIGINAL: disturbed471985
RE: notched pistons
Sad to see the situation your in.[:@]Been here a trillion times.
I would remove the engine from the vehicle.
Purchase .030 over pistons with the reliefs on them.
Have thenew pistons balancedthe old piston's weights and pressed onto the rods.
Thenhave the block bored and honed.
Replace the Rod and Main Bearings (.010).
Replace the oil pump and shaft, and clean out the pickup .
Turn the crank over .010
$500 well spent, and more power than you are expecting. With your mileage, im sure your at least 35% less power than you had from the factory at the wheels.
Besides the lower redoneandlabor saving's, having the motor out of the car takes alot of time and pain off your project.
Something else you want to look at, are the "OTHER" gadgets they used to get 360HP, besides the HCI.
It may take you days or weeks, I can rebuild a 302, do the HCI and have it running in 8 hours after the machine work is done. But then you rest assured, you will not go there for many years to come.
uberstang1
09-20-2015 06:42 PM
