Exterior Door Handle Help!!
I need to replace my exterior door handle on my 89. No big deal i'm sure but I'm not customed to anything outside of the engine so what tool and I going to need to replace it? Any help would be appriciated.
RE: Exterior Door Handle Help!!
you have to drill out the center of the rivet. and then get the correct size gun to re-do the rivets with the ones that they gave you, they are big rivets so they are also a PITA have fun
Here's what ya' do...
1. remove inner door panel
2. unhook the linkage bar at the handle
3. drill out the old rivets
4. remove handle
5. put new handle in place
6.buy stainless steel, pan head, allen key,bolts and nuts from Lowes or Home Depot
(they should be about 1" long with a head about the size of the old rivet head)
7. Put it all back together and admire a job well done.
That's what I did... it's easy andit looks great!
4. remove handle
i didthe bolt thing that way you never have to worry about the rivets again, and you can take off and put back on as many times as you want, then if you want paint the heads to the mactch color of the handle, its flawless
mungodrums
Suspension
09-24-2015 10:12 PM
