How high of a lift can stock springs handle?
Old 08-11-2008, 12:47 AM
tw3ak
tw3ak's Avatar
Default How high of a lift can stock springs handle?
tw3ak is offline
Old 08-11-2008, 12:54 AM
jtmustang
jtmustang's Avatar
Default RE: High high of a lift can stock springs handle?
not much more than stock .444 i wouldnt go any higher than like a b cam .480 and thats if u have a somewhat low mileage motor..?
jtmustang is offline
Old 08-11-2008, 12:56 AM
tw3ak
tw3ak's Avatar
ORIGINAL: jtmustang
lol are u kidding? I had a e303 in no problem. I know its way higher than .444
tw3ak is offline
Old 08-11-2008, 01:04 AM
somedudeboy
somedudeboy's Avatar
If you are such an expert, then why did you feel compelled to ask?
somedudeboy is offline
Old 08-11-2008, 01:08 AM
tw3ak
tw3ak's Avatar
ORIGINAL: somedudeboy
Who said I was an expert..Smart ***.. keep your comments out of my thread
tw3ak is offline
Old 08-11-2008, 01:12 AM
jtmustang
jtmustang's Avatar
cause the stock ones were not meant for much more than stock and will cause valve float/bind at a much lower rpm = losing the full potential of the cam...
Old 08-11-2008, 01:19 AM
AdderMk2
Banned
AdderMk2's Avatar
stock springs are barely good enough for the stock cam... the ony reason the E cam worked with your stock springs... is because you didnt know any better than to change them.
I can assure you, if your car had been run on the dyno, you would have seen valve float up igh in the rpm's b/c the stock springs are meant for stock equipment
AdderMk2 is offline
Old 08-11-2008, 01:26 AM
tw3ak
tw3ak's Avatar
so how do you determine what size/type spring you need for what lift?
tw3ak is offline
Old 08-11-2008, 01:27 AM
AdderMk2
Banned
AdderMk2's Avatar
most good cams will tell you what spring set should be used with them.
however, IIRC there are only two spring kits that fit stock heads without machine work... and running a aftermarket cam WITH stock heads, is a HUGE waste
AdderMk2 is offline
Old 08-12-2008, 07:44 PM
5spd GT
5spd GT's Avatar
For simplicity sake, let us just say the stock valve spring is installed at 1.800" exactly.
You then compress the spring until the spring rings connect each other and that number is 1.300".
That gives you .500" before coil bind occurs. You will want ATLEAST .060" of leeway before that coil bind contact, which makes it .440" of useable spring travel.
Then you get into open and closed spring pressures, weight, style, etc.
General rules, but they can be twisted:
Racier lobes = Higher spring pressures needed = More potential flex
Street lobes = Lower spring pressures needed = Less potential flex
Lighter valvetrain = Less spring pressures needed = Less potential flex
5spd GT is offline
Quick Reply: How high of a lift can stock springs handle?
