Valve Covers for TF TW?
I found a whole bunch of valve covers that are "Tall" on summit... will all of those fit over the TF TW heads? Also i saw a select few that said needs intake manifold spacer to clear throttle body, is that required for all tall valve covers? And are the baffled that muhc more benneficial?
RE: Valve Covers for TF TW?
One other question... i was looking at cams and a "suggested part" was Chromemoly pushrods. I was thinking about getting a cam soon after the heads anyway but if buying them at the same time saves me from having to measure pushrods and order them seperate i may just save a bit more money and buy them together. Are the length of the pushrods dependant on the cam/head combo?
oh and which cam is better?
Heads:
http://store.summitracing.com/partde...p;autoview=sku
Cam:
Pushrods:
http://store.summitracing.com/partde...t=TFS-21406250
Thanks sorry for all the questions.
Heads:
Cam:
Pushrods:
Any of the the tall valve covers will clear but you will need a 1" spacer to clear the TB with those covers. On our heads you can use a short cover as long as they do not have the baffles in them. With a short cover you will not need a spacer.
To answer you pushrod question, we recommend that you measure for your pushrod length. Normally on a stock motor the pushrod length will either be 6.700-6.750" in length depending on the deck surface.
Okay thank you that is very helpful for the valve covers.
I will still have to measure the pushrods even if i am using a trick flow cam, head, and intake?
also, what benefit does the baffle have?
i am using trickflow short valve covers on my twisted wedge heads no problems and no spacer needed.
and as far as the cam i am running the stage 2 cam which is the second one of the 2 u listed and i ended up using 6.700 trickflow chromeoly pushrods for my setup with crane 1.6 roller rockers.
the stage 2 cam has a quite lumpy idle and after about 2800-3000 it really kicks in and pulls like a mother...i like so far as i still need to get my car tuned so i can drive it around town a little easier..
you dont need to have it tuned to run really well, I have a larger cam than the stage 2 and it ran fine before I added a bunch of fuel to it on the dyno to get the air fuel in check
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
