EGR passageway in heads
does anyone know how i can find out if i have egr heads or not, i think my "former" machine shop gave me back a different set of heads on my motor, i know during reassembly i had to heli-coil a bolt hole for the alternator and power steering brackets, two holes were all the sudden bigger than they were before.....anyway i am having egr problems "code 84" that i cannot get to go away, i have tried everything, so maybe the machine shop f----d up and put a different set of heads that happened to not be egr heads on my motor ..............any feedback would be helpful
you were missing the inserts that screw into the air injecton passage. there no egr ports in the heads, but air injection, pumps fresh air into the intake ports to help burn everything in the cats. the front of the heads are blocked off by an insert, threads on the outside and the inside(so you can screw a bolt into it). they arent really expensive at the dealer but last time i needed them it took my parts guy a while to find them on the computer.
Assuming the valve is opening, if the engine doesn't stumble or stall = either no EGR port is present at the heads or it's blocked. Code 84 though, is a problem with the EVR circuit + it should not create any driveability, A/F or spark advance control problems....... the EEC deletes the EGR function automatically without affecting anything else.
Originally Posted by jssblues
in fact i tried almost taking the egr right off and running koeo and still get code 84
