code 92 and 42
code 92 and 42
so i get code 92, so i swap the o2 sensors, then i get code 42, so that should tell me "according to people on here that one of my sensors is bad, right????
so i go spend like 50$$$ on a new sensor, hook it up and get code 92, so i swap my old sensors and still get code 92, so i swap the new one to the other side and get code 42, same situation i was in before only now i am 50$$$$$ poorer than i was before.....
some real help would be nice.....................
Switched sensors........
Bank 1 = 42 and bank 2 = OK
Replaced sensor..... which one?.... bank 1 or 2?.... it should have been the passenger side..... was it?
After replacing the sensor, did you clear codes, started the engine, waited coolant to be at op temp, test drove it for 5 minutes, and then ran the KOER?
lincolnshibuya
12-08-2015 04:37 PM
