if i dident have bad luck......... blown head gasket maybe?
Id take more preventive measures to prevent detonation.
Colder Range Plugs
93 octane
Lower Degree Stat
Sea Foam to clean the carbon inside the motor
Check Fuel Delivery and A/F Ratio.
okay ^^^^ that helps the op none ..........detonation destroys components not so much gaskets, the extreme pressures generated within the cylinders as a result of using nitrous oftem will lift the head of the surface of the gasket sealing area and blow a gasket, you'd be amazed at pressures generated internally.........I'd buy a block check kit and test for a blown head gasket which is quite possible when using nitrous
They sell them at sears, I got a craftsman kit a year ago, I dont remember what i paid, I think it was 80$. If your near fayetteville for some reason, I can let you use it
