$2000 spent and still not fixed!
Old 05-13-2005, 03:55 AM
steveo1kinevo
steveo1kinevo's Avatar
Default $2000 spent and still not fixed!
I really need your help with my car. I have a 95 Ford Mustang GT 5.0 which is a manual. The problem I have is that when I am driving it the RPM gage all of a sudden jumps down and the car feels like it hesitates and is cutting out and sometimes stalls while driving. I have taken it to a Ford dealer who had it for two weeks and another garage who also had it for another 2 weeks and neither have found the problem!
The parts that I have replaced so far trying to fix this are a New Battery/New wires that go from battery to car/Ignition module/fuel pump,now 190LPH/distributor rotor and cap/and new spark plugs. They also ran computer tests on the car and it comes back ok at both garages but I STILL HAVE THE PROBLEM!
I really need some good advise on where to look to solve this problem. My car is all stock and Ford has no clue on where to look anymore.[&:]
Thanks for any help.
Steve
steveo1kinevo is offline
Old 05-13-2005, 11:46 AM
stanglx2002
stanglx2002's Avatar
Default RE: $2000 spent and still not fixed!
did they check the ignition switch i would check or replace that its a cheap part that might fix the problem
stanglx2002 is offline
Old 05-13-2005, 11:47 AM
1BADASSLX
1BADASSLX's Avatar
did you replace your coil ?
1BADASSLX is offline
Old 05-13-2005, 12:18 PM
sastangman
sastangman's Avatar
sounds like gummed up injectors or bad injectors
sastangman is offline
Old 05-13-2005, 12:34 PM
stanglx2002
ORIGINAL: sastangman
put a can of seafoam cleaner in your gas tank to clean your injectors
Old 05-13-2005, 01:48 PM
steveo1kinevo
Thanks for the help so far guys. They did not replace the coil just the rotor and cap. I just had the injectors cleaned also. I am about to take it back to the garage in a few minuites and they are going to try swapping out the whole distributor.
Thanks again for the help guys and if you think of anything else please post because I will be telling the garage all of your ideas.
Thanks, Steve
Old 05-13-2005, 02:11 PM
stanglx2002
ORIGINAL: stanglx2002
Old 05-13-2005, 10:41 PM
88GT40
88GT40's Avatar
it sounds like your mass air meter is bad, I had the same problem the other day, and it turned out the hose clamp that held my air intake tube to the throttle body had come loose and disconecteted and as soon as the maf read no air it did that.
88GT40 is offline
Old 05-13-2005, 10:55 PM
C/Note
I ♥ Acer
C/Note's Avatar
ign control module...
C/Note is offline
Old 05-14-2005, 01:08 AM
Stinger
Stinger's Avatar
I had same problem would work fine for 2 weeks sometimes then BAM. Try borrowing a computer from a friend i bet that cures ur problem. I was told A9Ls never go bad. Well Never happend to me. Good luck
Stinger is offline
Quick Reply: $2000 spent and still not fixed!
