Interior Lights/Blinkers stopped working
Old 08-25-2008, 05:20 AM
ravyn50
ravyn50's Avatar
Default Interior Lights/Blinkers stopped working
Welp, over the last couple of weeks my cars blinkers and interior lights have been working on and off. I have checked all fuses and they are all good. I've read a bit about that the factory headlight switch going out can cause something like this, but why would also the blinkers go out? Could it be the blinker switch?
Also, having some issues with my aod. My car will not shift into park whats so ever. It will shift into any other gear but when you you put it in park it'll stick in place but only shift into reverse. Could this be the linkage to the shifter? The fork seems to keep the shifter into place but it won't go into park.
Thanks for any info you guys have.
ravyn50 is offline
Old 08-25-2008, 06:25 PM
ravyn50
ravyn50's Avatar
/bump
ravyn50 is offline
Old 08-25-2008, 09:07 PM
50GT
50GT's Avatar
Check out my post on the headlight switch it might help.
50GT is offline
Old 08-26-2008, 09:41 AM
chet3310
chet3310's Avatar
Fuse or relay
chet3310 is offline
Old 09-01-2008, 02:23 PM
chaotic50
chaotic50's Avatar
not sure if you have fixed this problem yet.. but this thing caused my blower motor to not work along with my blinkers and a few other things.. oddly the car would still start and run fine.. good luck
http://www.latemodelrestoration.com/...0%201&comp=LRS
chaotic50 is offline
Old 09-01-2008, 02:30 PM
chaotic50
chaotic50's Avatar
try this... it caused my blinkers and blower motor to stop working... http://www.latemodelrestoration.com/...0%201&comp=LRS
and this caused my uncles interior lights to not work... i just filled the contacts and spring a bit with sand paper and fixed that problem...
djbigskrilla
09-20-2022 01:04 AM
Never2mucHP
13
06-06-2021 10:12 PM
importsmasher
10-09-2015 04:42 PM
m4xx
09-01-2015 06:46 PM
Tyoung68
08-25-2015 04:31 AM
Quick Reply: Interior Lights/Blinkers stopped working
