stumped on tranny!?
Old 08-26-2008, 10:41 PM
Hung Like a Stang
Hung Like a Stang's Avatar
Originally Posted by AdderMk2
was the car originally a auto or 5 speed
+1 if it was a 5 speed before, don't be an idiot like me and forget to take the pilot bearing out.
Hung Like a Stang is offline
Old 08-27-2008, 07:17 PM
84_302
84_302's Avatar
it is 8 1/4 long and the old one is just 8.. it is an automatic and always has been
84_302 is offline
Old 08-27-2008, 07:40 PM
84_302
84_302's Avatar
Originally Posted by reddogg
did you make sure the old dowel pins were out of the tranny
Whats that?
84_302 is offline
Old 08-27-2008, 08:28 PM
MustangMan628
MustangMan628's Avatar
Originally Posted by 84_302
Whats that?
I assume he means the 2 pins that align the bell housing and the back of the engine block. Should be one on each side if I remember correctly
MustangMan628 is offline
Old 08-27-2008, 11:15 PM
silver91gt
silver91gt's Avatar
automatics use flexplates, not flywheels.
if you look straight down the front of the bellhousing the converter should be just a little bit inside the bellhousing, if its not then its not seated right.
silver91gt is offline
Old 08-28-2008, 08:20 PM
84_302
84_302's Avatar
Originally Posted by ewgoetz
The flywheels are also balanced to the engine not the trany. May want to put back the old flywheel.
yeah put the old one back on.. and i took te bellhousuing off the c4 and it slid right on.. it had to be that that shaft is to long.. can i grind it down or any way i can rig it up? like a spacer or something.. i have a plasma cutter i can use to make one
84_302 is offline
Old 08-28-2008, 08:40 PM
LX 90
LX 90's Avatar
ok so is the bellhousing binding up or are the bolts just going in all the way and bottoming out. i just did the swap and the bolts form the AOD are to long and you have to use shorter ones....
LX 90 is offline
Old 08-29-2008, 12:17 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
If the bell goes on no problem then yea it sounds like the converter isn't seated right....OR somehow you got stuck with the bigger torque converter when you got the c4. You really need to get a pic up here with the converter installed on the tranny so we can see where you are at.
AND DON"T CUT THE SHAFT!!!!!!!!!!!!!!
projectresto83 is offline
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
stangin1996gt
09-21-2015 11:01 AM
prophotog
09-15-2015 08:38 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: stumped on tranny!?
